Hey guys is there a way to run good gas through the car without draining the tank I just filled up?I got a bad miss after fillling up today just cruising enjoying the weather.I did change plugs but no differance my car is stock except cold air kit .Latest Scanmaster numbers are:
af5
lb40
bat13.6
int136
blm147 up from 122 last check
clt185
ats97
rpm725
tps.46
iac59
cc26-250
no mal codes
I've owned this car for several years but just got into to tuning it lots of fun when when its running good but it gives me a major headache trying to figure out some of the promblems.I got a power plate and a lt1 with trans later coming going to upgrade injectors and fuel pump also.Like to be able to drive it most days. you guys are always very helpful thanks
af5
lb40
bat13.6
int136
clt185
ats97
rpm725
tps.46
iac59
cc26-250
no mal codes
