Ive got a no start condition with the stock engine I put in (while mine is out for rebuild). I remember this was the reason that my brother stopped driving the car that this engine was in some years back. It was the first TR we had experience with (first FI car for that matter). Now that I know quite a bit more about them, Im betting a injector(s) are stuck open, if thats possible. I want to see what you guys think.
Currently FP is not holding and I smell gas (shoots up like normal, then falls down quickly). Sounds like its trying to start. I remember symptoms back when the engine did run to be ocasional backfiring and black smoke with raw gas coming out of pipes
. It finally just stopped running.
Cam sensor, coil/mod, ECM, AFPR, FP gauge are known good from my motor that I just took out. The crank sensor is new. Only thing that I can think of that it could be would be injectors. What do you guys think? Can injectors be stuck open?
Oh yeah, I also remember doing compression tests on this motor before while it was still in this no start state, but in the other car. Compression was very even through all cylinders at 120.
