BlackBandit
God loves Buicks!
- Mar 29, 2003
This is a crush sleeve issue and tightening it down until lash is righ is wrong. This preloads the pinion bearing and bearings have a general spec of 15in.lbs. of turning torque for used bearings and 25in.lbs for new bearings. Over tightening them will blue them and over heat them. This needs to be done right. You can tighten the pinion nut back down to where it is just taken the play out of the pinion but it is best to disassemble and do it right vs bandaid it and causing more damage down the road. Sometimes it works and sometimes it won't.
So we're clear I didn't say it was right, I said it was better than nothing. Your post is right on though.
