First things first, set WOT by pulling the sensor all the way forward as far as it will go. Tighten down both screws just enough to hold it in place. Now loosen the top screw a little, enough to to allow the nose(front) of the tps to be rotated up or down a little. Just use little "taps" to move it up or down to change the idle tps value. then tighten and recheck values.
