balanced rotating assembly, custom cam, built trans etc..
BuickGNturbo87
Balanced rotating assembly
Diamond forged pistons - .020 over
stock crank - balanced and re-condition - all this goes for $800 obo
stock rods - balanced and recondition
balanced flywheel
custom cam - comp cams - $175 obo
champion gn1 ported intake manifold - $400 obo
built 2004r - $750 obo
drive shaft with beffy u-joints
stall converter - 10" pro torque - 3200rpm - 3400rpm - $600 obo
stock torque converter - lessened up to stall around 2800 - $250 obo
comp. chip for the pt 61 - $50
walbro 340 fuel pump - make offer
rear end components
3.73 Richmond ring and pinion
limited slip diff - not sure what kind its been awhile since i put it in
stock 28 spline axles
any questions please pm me or my cell steve @ 414-364-7004
Could you tell me specs on your custom cam?Here is some of my info,87 stock
bottom end,ATR headers & 3" DP,3" dual exhaust,JW 32-3400 stall,GT 6152e
turbo,Turbo tweak chip,stock 8445 ported&polished heads,stock valve train &
intake manifold,tin man cold air intake,LS1 afs,its a daily driver.I have heard i
should use a 212 212 cam!What do you think?,How would your cam work for
me?Let me know.
Thanks,
John
