Ball Bearing Turbo User, WARNING! Check your Fittings!
jdpolzin
Hey guys, I'm in the process of finishing up the Stage project and finally got around to instaling the turbo Saver kit. The fitting provided to adapt the oil feed line to the turbo, with the restrictor, had a slug still in the restrictor hole. This could have been really bad had that little slug bent over and covered the tiny hole the oil flows through. It looks like the tiny hole was drilled and the slug bent over inside the fitting instead of falling out. I took a clothes pin and bent the slug back and forth until it finally came out. Just a warning, hopefully nobody else has this problem but just be sure to check it out before you install it. -------Jeremy
