An interesting theory about the frozen ground/concrete. I agree cold temps lessen the time a battery will hold a charge. That seems to be pretty much accepted fact (I googled...)
My thought is I have quite a few 1 gallon jugs of spring water I keep on hand for when our power goes out. I took two camping with me in January and when I came home set them on the garage floor.
They are sitting right next to the batteries and they have never frozen.
Are they any colder than if they were sitting on a block of wood?
That would be a simple test compared to trying to determine which batter is colder.
I should put one on a 4x6 and leave the other on the ground. Wait a week...then measure the water temps.
That should give some indication of "do objects placed directly on the garage floor cool more than objects elevated off the floor"?
Sadly, we had 67 degrees the other day so the entire garage floor fogged over with a mist of water and the one thing I know is no water collected under the battery sitting on the wood.
FWIW - keeping the batter off the concrete is keeping it cleaner
I just took readings on the batts:
block of wood battery = 12.64 volts
dirty, wet-bottomed battery on concrete = 12.61 vots
After one month I can 'scientifically' conclude:
1) the battery sitting on the concrete floor of my garage has a wet bottom
2) the battery sitting on the concrete floor feels the same temp to my palm as the one on the 4x6 (hand against side of battery case) VERY precise...
3) the battery sitting on the concrete floor has a 'DECREASED' voltage compared to the one on the block of wood....
Decreased by .03 volts.
It has only been one month.
Tune in one month(ish) from now and I will take a reading again.
PS - should I endeavor to test the temps in the water jugs and place one on a block of 4x6 to see if the air cools them as much as being in contact with the ground?
