Flyin Brian
- Jun 18, 2011
I blew a head gasket last year and finally finished tearing down the motor.
I got some water in the oil when the gasket blew. Bearings do not look too good. About 1000 miles.
Crank was turned during last refresh and still looks perfect. Line bore was done when installing the steel center mains and ARP studs several refreshes ago but I am beginning to question the main bore alignment. The rod bearings look funny too. I don't know how much of this is due to the water getting in the oil. I had the big ends of the rods measured last time and they were in spec. I had a machine shop check the main bore last time and they said it was ok but I do not know how they checked it. I have since changed machine shops and am going to do all of the assembly work myself this time. My plan is to get everything checked and do all of the necessary machine work as well as replace any parts that are out of spec. This will be the re-build where I finally get everything right. Here are the bearing pictures. What do you think?
