OK, Here's the story. I recently purchased a used short block knowing the bearings were done. Here's what I found inside. I'm not worried because all I needed was the standard bore block to send off to the machine shop, anything else that I can reuse out of it is just a bonus. I'm just curious as to what you think.
Anyway, who can tell me what went wrong here. It looks like #2 and 3 mains took the worst of it. The bearing in #3 is actually pulling away from the cap as seen in the pics. Some of the damage is from debris, but I'm guessing that occurred after the bearings started to fall apart. There was no metal transfer between the block and caps like you would usually see from detonation. All the rod bearings don't look bad at all. The crank did spin nice and free. I haven't measured the main bearing bores yet to see how out of round they are.
