streetwavesauto
- May 25, 2004
1986 Buick Regal T-Type
White Exterior with Black Out Trim and Blue Interior
One Owner Car with the Original Title from 1986
Car has approximately 72000 Original Miles on the Body
The car was previously modified and has been returned to close to stock condition
The car was in GMHTP and a copy of the magazine will be provided to the new owner
Contact Info: Scott Zimmerman / 512.671.0848 / s.zimmerman@spi-bpo.com / PM me
Mechanical:
Fresh Engine and Transmission - Currently Less than 20 miles on engine and transmission
Engine – Built to Stock specification with the exception of Billet Main Caps and ARP Studded Bottom End
Transmission – Rebuilt with mild shift kit and billet servo
Fuel Injectors – 42.5lb
Boxed Rear Upper and Lower Control Arms with New Bushings
New KYB Shocks Front and Rear
New Moog Sway bar End links
New Firestone Tires on all 4 corners (235) slightly wider than the stock (215)
Fresh Transmission Fluid / Gear Fluid / Oil / Radiator Fluid / Brake Fluid
Wilwood Manual Proportioning Valve to adjust the brake bias
New A/C Delco Fuel Pump
New Stock MAF Pipe
New Turbo Hose Kit and Clamps – Black
Stock Air box Setup with New Filter
Stock Exhaust
TurboBuicks.com Mini-Starter
4 Core Stock Style Radiator with Oil and Transmission Cooler Built In
Everything else on the driveline is stock
Optima Red Top Battery Retaining Stock Battery Hold Down
Mechanical:
New Stock MAF Pipe
Stock Exhaust
