buickbuggy
- Oct 26, 2012
I took the buggy out this past weekend and the last ride started hearing a knock so pulled the valve cover on the side with the noise once I got it home and 1 of the plastic rocker arm retainers let go. There was 1 rocker arm off and the other one for that cylinder the push rod is bent in 2 places and stuck in the head (can't pull it from the top so might have to pull the head to get it out). If I have to pull the head anyways I'd like to look into getting the heads worked for more power (might as well while they're off
and am wondering what I could expect to pay and what my options are. I run this in the sand only and have an NA motor from a 1984. I'm not sure what else might be done but am beginning to think it's just the cam, intake, carb, hei ignition, and exhaust. The wife won't allow any crazy spending, so I'd like to get the most bang for my bucks. Thanks for any help/suggestions.
