I like the ORB seals. I am going to cut some cost by using one fitting on the hose that will go directly into the oil pump plate. Much cleaner install this way also.
I think DLS has all the correct fittings in stock. I should have just got the fittings from them.
The -12 hose fitting is the largest and most expensive one needed, around fifty dollars (one of them was around forty dollars) if I remember right. I ordered all of these -12 hose fitting, so I could find the one that would work with out notching the frame. Only to find out they all clear the frame. I like the transition on the Aeroquip fitting best.
From left to right Russell 612280, Earls 849013erl, Aeroquip FBM1359.
