I need some help on a front seal issue. I redline around 7400 to 7800 and my front seal is wearing faster than I like. What front seal are you guys using that takes the higher r's.
I'm also still using the OEM oil sling. Would I be better off removing the sling so that some oil can get to the seal to lube and cool it?
I'm presently using a National seal. Black rubber. It has oil pumping ribs on the lip. Comes in the felpro gasket sets I believe.
The numbers on the seal are S-12623 and K100674R. There is also a 1-16 on it.
