Best GN Front Brake upgrade?
It depends on what wheels you are planning on using. I think the Blazer brakes are the best bang for the buck that fit in the stock wheels. If you go to bigger wheels the options really open up, but I don't know enough about them to tell you what's best.
Use the SSBC front two piston caliber works great and you do not have to that switch out of front components.
I'm in the middle of doing this right now. Was tempted to do tubular control arms while I had everything apart but the budget won't allow it.:mad:
Using the Russell Stainless flex lines and some Raybestos drilled/slotted rotors. need the bling factor.:D
