RJC gets my vote. Hundreds of WOT blasts on mine. For those of you experiencing detonation in your 550+hp engines, you are hurting it regardless of the headgaskets ability to stay intact. The headgasket doesnt increase the clamp load in the deck surface. If you detonate with any gaskets you will lift the heads at high hp levels. Having Champion pin the area on the intake side of the head near the combustion chamber will help with cylinder head deflection that is common in high hp engines.
