SignUp Now!I................ I personally think if you are clogging filters with lead from gas you got bigger problems, like maybe ring seal, but I am not a engine builder or claim to be. I was a dealer for Amsoil also and I think their products are not junk. I talked to Dan today and he said to run Wix filters (My race motor) so I'll just do what he says as usual... :biggrin:
A lot of good advice on the oil filter choice. "Hasting" makes Amsoil oil filters, my personal choice. Don't recall the micron size filter media though. I ran the "Puralator Per 1" big oil filter on my last GN, with the large filter adapter. Engine use does determine what works best. I was told never to use synthetic oil ever in my last ANS Engine or in the rear end. (Pete B. and my rear end builder's advice) My SRT8 Jeep, 6.1 Hemi came with Mobile 1 0W40 right from the factory because of very tight oil clearances, so in that case syn was OK. Filters with a good drain back valve is a must. MHO Gene
Funny as I used to take of an account that printed shipping boxes and "Amsoil" filter boxes were sent from Hastings Factory. Not a recent observation but still was noticed by me. Personally, I don't like Amsoil. No flame to anyone just bad experiences using their products. I was a former Amsoil Dealer and used it in my first 87 GN and other vehicles. Filters are the main subject matter and of course up to their application determines which one works the best. The Per 1 uses a "Viton" drain back valve and probably a very small micron filter media so in some instances it would not be the best choice. I always use a very good oil filter and chosen not by price. I used the K&N oil filter on my 6.1 Hemi Engine but at $12.50 ea, a spendy one for sure. Another View. Gene
Just did a oil change on my buds Blackbird stg 2 Firebird and we used a Amsoil EA Filter.
Could not get it to seal!!!
Pulled it off double checked all the seals and evrything reinstalled and still leaked (yes the filter was filled and seal lubed pre install and not overtightened).
Went back with a mobil 1 extended perf filter and all is well.
I'm sure that was a fluke. I never had a problem even with 100psi cold pressure. Are you sure you had the right 0-ring size?
