Best on street radials?
chadly
What is your best 60ft on street radials? About 1.88/1.9 is the best I can do.
What "street radials" are you talking about here. I bet you a dollar my MT street radials will get me out of the hole a good bit quicker than that...
I’m talking about street radials, not drag radials. Mine are Cooper sand and snow. I know there are much faster than me, I’m just curious.
Man I bet if I left on Cooper all season tires I would be cutting a lot worse than a 1.8 or a 1.9 :eek:
You must have a gentle foot, I was not born with one of those :wink:
That's pretty decent for those tires. My gn is set up a lot like yours, same turbo and stall speed on the converter. I am guesstimating a 1.7 or quicker off the nitrous, and quicker than that if I keep it from spinning.
1.89 on Goodyear GSC radials. un-opended motor, Stock convertor, stock turbo,stock injectors, stock chip, stock down pipe with a $20 cutout before the cat, K&N filter, external Fuel pump, piggyback fuel reg, 20psi 62 psi fuel WOT.
12.92 @ 108mph. in 1992. I still run the same GSC-s on the front, but now I run MT DR on the back. Best 60ft with current DR is 1.73.
On my Chevelle I managed a 1.87-1.91 60 ft. That was with a pair of 275/60/R15 M/T ET street drag radials. 12 psi of air in the tires, 396 big block pushing like 425 hp at the crank, 3k stall, 4.10 rear gear.
I bet there was a wee bit of tire smoke on that launch huh :wink:
That was a pretty clean launch! Did you leave at idle or were you leaning on the gas/brake while the lights dropped?
1.82 60ft on 225 bfg traction t/a, def. not a drag radial! the run before this one i ran a 14.3 in the quarter because i blew the tires off for the first 330ft. launched at 10" of vacuum:eek:
I drove mine on the street and their description says street and DOT approved.
ET Street Radial
Worlds Fastest Street Radial!
Mickey Thompson's legendary race tire technology comes to the street with the ET Street Radial. Built using the latest in high tech radial construction techniques and years of drag racing experience and compound development, this D.O.T. approved street legal drag radial will get your car down the track in record time and drive you home with sure handling and an excellent ride.
* Soft Compound For Superior Traction On The Drag Strip
* Radial Construction for Excellent Ride Control on the Street
* Low Void, Directional Tread for Maximum Dry Traction
* Special Sidewall Construction for Quick Launches.
CAUTION: It is not recommended that radial and non-radial tires be mixed on the same vehicle..
MICKEY THOMPSON COMPOUND SELECTION CHART
Medium--------------------------------------------------------Soft
R2
R2 - Special Compound for ET Street Radial.
Click to Enlarge
Part # Size Size
Equivalent Appx.
Weight Compound Approved
Rims Measuring
Rim Sidewall
Width Tread
Width Overall
Diameter Circ.
3752R P235/60R15 26 X 9.50R15 27 R2 6.5-8.5 7 9.5 8.4 26.1 82
3753R P275/50R15 26 X 11.50R15 31 R2 7.5-9.5 8.5 11.3 10.5 26.1 82
3756R P255/60R15 27 X 10.50R15 30 R2 7.0-9.0 7.5 10.1 9.0 27.1 85
3754R P275/60R15 28 X 11.50R15 33 R2 7.5-9.5 8 11.0 9.5 28.0 87
3757R P325/50R15 28 X 13.50R15 37 R2 9.0-12.0 10 13.1 11.6 28.0 87
3762R P295/65R15 30 X 12.50R15 38 R2 8.0-10.0 8.5 11.9 10.9 30.0 94
3763R P315/60R15 30 X 13.50R15 39 R2 8.5-11.0 9.5 12.9 11.9 30.0 94
3793R P255/50R16 26 X 10.50R16 29 R2 7.0-9.0 8 10.5 9.6 26.1 82
3743R P275/40R17 26 X 11.50R17 28 R2 9.0-11.0 9 11 10.0 26.0 82
I did a 1.87 sixty foot with Sumitomo 255 50 16s, and managed a 12.3. It's hard ot get a good 60 on street tires. Never did any better. Lately I'm lucky to get 2.0s on my 17" tires. :(
