K kcdano2017 New Member Joined Apr 29, 2017 Sep 10, 2017 #1 Looking for a new reg joint and front sway bar.
1986 Buick GX1 GX1 #001 [The One and Only] Joined Apr 24, 2015 Sep 11, 2017 #2 Check out www.kirbanperformance.com for the rag joint or his upgraded steering shaft that has u joints and uses no rag joint. You may want to post a parts wanted add in the marketplace section for the specific front sway bar you're looking for.
dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Sep 11, 2017 #3 I would buy a jeep steering shaft and just ditch the whole rag joint . You will notice the steering tighten up if u do the jeep shaft .
