Best rotors
Sal Lubrano
When looking for maximum performance and stopping power which rotor should be used. Slotted, cross drilled or slotted and cross drilled.
ACDelco Parts
Look at the performance rotors in the link. Stay waway from cross drilled rotoirs they will crack between the holes.
Run a real good quality aggresive compound brake pad and youll be fine. Aslo get Russell SS brake lines...... BIG difference
Thank you for the info. When you say run an "aggresive compound brake pad" what would be some brands to look at.
More aggresive compound. Hawk HPS or EBC yellow, higher quality metallic pad at the parts house, etc.
Idea is with the higher quality compounds that you dont get the organic burnoff/gassing.
