best T Chain to use..
fatride
Senior Member
What is the best/strongest Timing chain to run? I have an On Center Stage headed motor, 232/232 solid roller cam. The car will be 75% street.. Maybe driven 500 miles a year.
Thank you
Solid roller with TA heads here. Don't know if it the best or not but I have had good luck with the Pro Gear timing set so far. I just changed it for preventative maintenance and to see how it was doing. The used chain looked good. I had 78 drag strip passes and about 200 or so street miles.
