Jerryl
Tall Unvaccinated Chinese Guy
What would you say are the top 3 non-performance and performance related mods you made to your car? Post some pics if you have some.
OK, I’ll go first.
Well, the lines get blurred between performance and nonperformance.
I am more less talking about things that made “PESKY” assembly easy or some small things that will make a difference. Not talking about
Here is my criteria - Try NOT to list mods that we pretty much all know about and/or are easy. Example; Upgrading the ECM is “easy” and we all know about it.
I’ll take a stab at it. This is just my opinion and you can list an state yours.
Non performance ……..
Turbo bracket - This is a gem! I take no credit for this one and belief Buickpower to be the originator. This is an awesome mod and saved me 2-4 hours of fighting the ******* oil return tube!
Valley pan gasket cutout – This will allow the oil to drain into the block and “hopefully” reduce the oil sucked up through the PCV. Easy mod to assist in combating pesky oil problems.
Interior painting – This is a GREAT mod for any enthusiast who would drive the car for a while. A clean and well kept vehicle should have a higher market value
Performance
Dual fans – Pushing the air for a “OEM” engine bay look. Fans are from a Nissan and I now have the platform set to adapt any dual fan.
Exhaust system locating pins - Allows repeated precision alignments. No. I do not plan to take them on and off, but, the ports and headers are “without any doubt aligned”.
TB O-ring – I did not want to worry about gasket protrusions and possible leakage so I added an o-ring.
OK, I’ll go first.
Performance
