This is the DP with the cast-iron wastegate housing with a 3" mild steel tubing bolted to the housing with spring bolts. I know there was a do-nut seal between the pipe and the elbow, but I lost it during a move. I've tried every local automotive and heavy truck retailer near me, Summit, JC-Whitney (I'm desperate, ok!), and National Gasket to no avail.
Where can I find a 3"id exhaust o-ring about 5/8" thick, beveled on both sides to fit this DP?
Maybe someone out there used to work for BGC and knows a supplier/part#?\
