BHJ and Timing
Blown&Injected
Now that there are lots more out there - how is everybody finding the timing on their BHJ equipped cars?
My car appears to be way retarded at idle.
After doing a search and some reading, I am going to check the timing with a light with the two pins on the ALDL shorted - should be running at 15* in that condition.
But first, I am going to draw a better line on the balancer - kinda hard to see what's going on down there.
4* Retard
For anybody that may be interested:
After painting the line on the balancer and shorting the terminals in the ALDL link, the timing was at 11*, not at the 15* marker on the tab as I beleve it should be in that state.
I verified that the tab was reading true TDC when I degreed the cam.
Yep,Thats about normal for a BHJ
Most car with aftermarket ecu will find they have
to set crank offset to 5 or 6*
Most stock ones i have found to be right on or even 1-2* advanced
