Well, after moving and having the BS3 for almost a year I finally got my car out of storage and installed the BS3. I haven't started the car yet because the fuel pump harness will not switch on with the HS lead from the ecu. The TPS wires were backwards so I will have to switch that. It read 100% at idle and when you pressed the pedal it went to 0%. lol I also noticed that the labels on the IAT and H2O senders were backward. I can bypass that for the meantime until I figure it out. I sent John an email and I'm waiting on a response. Maybe I will get it started today.. I have replaced everything on the car's wiring harness. I had Caspers build me a custom harness from the fuse box and C3I,cam, and crank harness to use with the BS3 harness. Trying to unclutter under the hood. I still have some questions about the setup but I will work through them as it comes..
