Big tires
bbbad6
6 Speed TR?
I'm thinking i can get a 275 tire on 17x9 rim with 4" bs. Does this seem ridiculous, It appears I may have to modify the plastic inner fender where it bules in slightly, but frame and sway bar clearance appears ok.
I run a 295/50R15 on mine with a 4 1/2 BS when I want to run street legal radials. I did have to install the air lift bags for clearance of the outer fender wells. The rim is a 10" width. The tires extend out about even the outside trim on the wheel well. Almost worked without the air lifts but not enough clearance for big bumps.
Pics please!:cool:
Give me an email address and I'll send them to ya. The wheel is a Diamond Racing Steel Wheel(black gloss). I only run them if I'm racing in street legal class.
Please specify if you are both describing fronts or rears.
I think bbbad is talking about a front, and the reply is talking about a rear.
Thanks,
J
