If MPE means mease performance. I called keith and hes doesn't have any. He is telling me my 1.23 puck is plenty big enough. Its the wastegate actuator of the F250 deisel and my grainger valve controler that are causing the problems. He said to get a heavy duty wastegate act and a inovative boost controler and my problems will be solved. I might have to weld the hole up a little even to get rid of my boost vanishing problem. The controller is $649. I really don't want to spend that much on a controller. I know ramchargers sells one for $149. But its not a stand alone and I would have to get another custom burnt chip to get my factory boost control back.
