Biggest turbo I can run with a 3200 stall?
GBGN1
stroked
Looking to up grade soon and i just got a great deal on a 3200 stall .I currently have a te-61 on the car right now is this capable of sub 10 sec runs?
with the usuall mods?
thanks
Brian
thanks
Brian
rjc told me that i could get away easy with my 3200 and a te 45(a) as long as i run thier 49 dollar hybrid boost controler. hey for 50 dollars im gunna try it!!!
thanks
Brian
as in 9s??? in the 1/4
you might want to list your definition of the "usual mods" because unless that list includes a rocket engine, you are going to be a little dissapointed.
to be honest with you, a 3200 stall on a te45 is going to be on the edge of what I would consider a good match. A 3200 stall and a te-61 is a good match.
I ran a 3500 stall on a pte54 and it was fun.... then I upgraded to a 71gtq it just wasn't enough. and to run nines you are going to need a bare minimum of a te45 turbo.....realistically you are talking about getting a 70/71 turbo to get those kinds of numbers and I just don't think a 3200 stall is going to be enough.....at all.
what are you currently running in the 1/4?
and what are you mods.
thanks
Brian
What is your combo??? :eek: :eek:
My 9x11 is supposed to stall at 3200, I'll let you know how the TE45A spools in a couple weeks ;)
Sorry for the mix up i ment sub 11's i just want to run mid 10's someday--soon.Havent been to the track yet with new combo--p&p heads and intake(210,175),3 inch dp,3 inch exhaust,50lbers,te 61,dutt neck(havent installed the fm yet)62mm jj tb,powerplate,pte chip.stock shortblock.
I actually would be happy with 11's right now--just wanted to grow into the 10's.thats all--cause i have that 3200 stall and i dont know if the 3200 and the te 61 will get me there..
WHats the limits with this turbo?
sorry for the confuseion --9's arent in me diet....yet :redface:
thanks all Brian
yeah please keep me posted same stall same turbo, so i am very interested :smile:
thanks all Brian
you have all you need for mid 10s now. You can make it easier....but you have the parts you NEED now.
thanks
Brian
Your TE61 will take you into the 10's easily. I kept my boost down to 21lbs max and I was running 11.1 - 11-2s all day. My engine wasn't girdled so I was a little concerned at the time, about driving over the crankshaft. Lots of guys going faster than that now on a stock 109 block with good parts and a good tune. I'm sure you can go mid 10's at 26 lbs. boost. :cool: :) ;)
Our track here is at 3500 ft. with air quality regularily around 4700 to 5200 ft. most of the time.
I was running a 3500 stall N/L.
Good luck with your project. Have fun.
George
A double ball bearing Innovative 70 P-trim spools just fine with 3200 stall. :)
