Bilstein Shocks = brand new
tnt6
I have a set of brand new Bilstein shocks that have yet to see the road..thay had been mounted to my chassis as my frame off continues to go together...decided to step up to a coil over set up at the last minute(as usual) $300 shipped for the set..
Here are the shocks
Interested do you have part #'s, need to check if they will fit an a-body
Sent from my RM-845_nam_vzw_100 using Tapatalk
Yes
1. G-PLUS arms bolt directly to stock spindles or 2 inch drop spindles.
2. The arms have additional caster built into the them and a improved camber curve. The combination keeps the tire contact patch flatter on the pavement verses stock.
3. A bump stop is installed on the control arm eliminating the stock one on the frame. The new bump stop location allows for a limiter, which can be installed for drag race applications.
4. Billet cross shafts and top of the line Del-a-lum bushings (which reduce suspension drag) are incorporated making this control arm superior for all applications.
5. New alignment specifications are included.
6. G-Plus control arms are offered with Del-a-lum bushings or polyurethane.
7. The control arms are shipped assembled with bushings, ball joints, billet cross shafts, and bump stops,
Part # CTA-88A uses Del-a-lum bushings
