Decided to "upgrade" to all long shoes in the rear so I changed the shoes, & also changed out the wheel cylinders as they seemed stuck and wouldnt move.
I bled brakes by having someone press the brake pedal while I loosen the bleeder until its solid fluid, seemed easy enough.
I go to test drive the car and it has no brakes, and the brake light would go on when you press the brakes. I do plenty of searching on TB.com and I didnt hold in the proportioning valve so Im thinking thats what it was. I was going to rebleed but when someone stepped on the brakes, from under the car you hear pfft, pfft near the valve, I dont know if that is normal, and the proportioning valve goes in instead of out. I put my finger on it to double check, engine was not running, dont know if that matters ( vacuum brakes). From the rear of the car when running, I hear a leaking air sound, but that may be exhaust, or even the fuel pump.
The thing on the valve that moves in looks like a bleeder valve, it faces the front. Could this be defective? It looks like iron, not brass. The brakes in this car were never that good. Thanks.
