An old post from the GNTType list:
richards@interactive.net (TR)
Subject: re: Speed Bleeders
Date: Thu, 30 Oct 1997 13:06:43 GMT
Jerry,
Just recently installed both front & rear Russell speed bleeders and
they're awesome! Had the entire system bled in about 15 minutes and
didn't need an assistant!
The bleeders have a spring and ball check valve to prevent air from
getting back into the system and a Loctite type coating on the
threads. One note of caution, the coating on the threads isn't as
permanent as they claim. It's O.K. if you just screw the bleeder in,
back it out 1/4 turn, bleed the line and retighten, but if you have to
take the bleeder all the way out for any reason (i.e. you replace a
wheel cylinder like I did!) the coating will disintegrate. If this
happens, simple recoat the threads with a REMOVABLE threadlocker from
Loctite or Permatex and let it dry a bit before you replace the
bleeder.
Part numbers are 3952 for the rear and 3958 for the front. They come
2 per package from Summit Racing at a cost of $12.39 per package.
Hope this helps!
They work as advertised. One man job. Over and out.
Buzz White in Houston, TX
(sumnerw@flash.net)
