Blocking off the EGR with a powerplate?
  • Thread starter Thread starter turbov6joe
  • Start date Start date
T
turbov6joe
Guest
Here is one for you all. Would using the RJC powerplate and not drilling the EGR provision cause excessive amounts of vapors to escape from the valve cover breathers??? Seems that since I installed the PP I have more than usual amounts of vapors comming from the breathers! I did not drill the EGR hole...TIA
Frank,
Here is my thinking be it right or wrong. If the only thing evacuating the crankcase vapors in this case is the PCV valve, and with a 218-218 cam that does not have much more than 11 inches of vacume at idle, how else do they get out except for the breathers? I thought the EGR was soposed to perform this function if working??? The best way I can describe it is it looks like an old whistling tea kettle spewing steam up in the air. In my motor's case, it's a "steamy" looking vapor that smells like exhaust that comes out with speed when I rev up the motor. At idle it kinda just eases out in no big hurry. I can plug off the DS breather with my hand and watch it expel out of the PS breather instead. IMO 11 inches of vacume is barely enough suction to overcome the check valve and make the PCV valve do it's job as intended. If my memory serves me right, didn't these motors have a tube from the PS valve cover to the turbo inlet bell? I would venture to assume that this in addition to a functioning EGR, a higher vacume producing cam, a PCV valve with no checkvalve in place, and a capped off DS filler hole, this steam would be non-existant... I am going to run a leakdown and compression test just for ****s and giggles; but mostly to set my mind at ease. The motor runs great, no loss of coolant, no bubbles anywhere, no misfires, no anything??? Anyone else care to shed their opinions on this matter? I may dril out the EGR portion of the powerplate to see what happens. Tell Terry and Franky Jr. we said hello.
Yea Joe, I think your onto something.. I have a mild cam so my vacuum is 17 in at idle, so Im a lil better off then you. And YES the factory does use a ps vc breather from the turbo bell.
I don't seem to have the 'boiling kettle' effect tho.. I do use an AC PCV and a kirban check valve.. I hope someone can shed some light on this..
Frankie and Terry are doing great! Hows your new addition and your wife? Hows Dad and Mom and Jen? Tell em we said HI
EGR vx PCV
The EGR valve, when working properly, should allow exhaust to get into the intake manifold, to "dilute" the mixture and lower combustion temperatures, and thus lower NOX emissions. Doesn't function at idle, I believe. The PCV system, on the other hand, uses manifold vacuum to pull junk out of the crankcase. It does work at idle, if the PCV valve is kept clean and working. Not drilling the EGR hole might make the car fail an emissions test, but I don't think it would have any effect on crankcase vapors and pressure. The connection to the passenger side valve cover from the turbo allowed the air going through the PCV valve to be "metered" by the MAF, so the ECM could control idle. (doesn't seem to work too well, though) Other thoughts?
