SCOOBY DOO
BASED CANADIAN PATRIOT!!
- Feb 18, 2007
OEM valve springs sat in a cup. Are the cups still present?
SignUp Now!That's troubling.Update; Got the pushrods, went to install. But first retorqued the heads, all 8 on both sides were lose....
At this point I'm going to have to check. I didn't want to initially due to not having a misfire when it was running with the clicking noise. But now after all this, its apparent I need to just for peace of mind.That's troubling.
Possibility the head gasket may have been pushed out.
Can you do a leak down test on each cylinder?
Ater being driven in that condition, I suggest you start a slush fund for head gasket replacement and cyl head work.But first retorqued the heads, all 8 on both sides were lose.
I haven't done a compression check. I was assuming I didn't need to do one because it wasn't misfiring while running. Also I'm not losing any coolant and there's no smoke in the exhaust.He did a compression check on the cylinders and they were all good.
Sorry I thought he had, my bad.ummmn..........Ok.
It cant hurt to try this! What part # is the belt? I saw on a youtbue video some1 using #4060630.Sometimes the belt stretches enough to allow the idler pulley to contact one of the A/C compressor mounting bolts.
Use the slightly shorter TTA sized belt.
