gunnervirus
My Car's Too Loud...
- May 29, 2001
Hi again,
I had an idea the other day (one of those don't just pop up everyday ) If I were to convert to a blow-through system (the current draw-through system intereferes with my hood, and the pass. side exhaust manifold interferes with the fender --it's a vega), I would replace the exhaust manifolds with ones from a 86/87, use a 86/87 turbo, custom fab the pipes, replace the intake and carb with aftermarket pieces. Would this work out?
What kind of carb could be used... I was thinking a holley 390, but is that too small for a turbo application? Since the carb would be under pressure, would I have to find another vacuum source for the vaccum advance? They're are no smog equipment on the car now, nor would there be with the blow-through system. Any recommendations?
Thanks again,
Ben Cotter
Thanks again,
Ben Cotter
