ITSAV6
It's my Granny's car!
- Nov 13, 2001
What head gaskets do you have? X2 on the knock sensor could be bad. Head gaskets are probably done. Had the same issue with ROL head gaskets. Ran fine but pressurized the cooling system under boost(ROL sux)and I hadn't been over 13#. Just go pull the heads and be sure to check the block and heads for flatness. And like Bison said check those beaings.I will tune my own car. The engine runs and sounds good.Yes I'm sure the head gaskets have some issues, but normal driving 160 coolant temps. Under boost blast she runs 220 0r so and cap blows off the over flow.. Boost gauge is accurate. Yes without data I'm stabbing in the dark. Time has run out over the winter I"m going to go over the engine..Thanks y'all for the info.
