turbomaster
 - Jan 24, 2005
I built this motor years ago with all the "good stuff". It has a virgin (not used) 109 block that came directly from buick with no VIN number on it. It has a new polished TTA crossdrilled crank, polished TR rods, TTA stock bore GM pistons, full balance, and a girdle to hold it all together. I stamped my SS number into it to indentify it as my motor, also in the RJC girdle that was machined to the block by G&M Motors in St. Louis. Balanced and machined by Mike Christianson, G&M Automotive. The heads are 8445's with a fresh valve job by allied motors in St. Charles Missouri. They are supposed to be 100 lbs on the seat spring pressure. I havn't checked it.. The intake, TB, plenum are included.
I have around 5K in building this blowproof 3.8. It has an 8.5 cr wtih 1 steel shim head gasket per side, to run pump gas with low boost, and not blow head gaskets or drive over the crank. I like to make it home!
It's a nice stock bore 3.8 with a NEW GM 109 block that will take you home. Aprox 5K miles on this baby.
$3500.00 or best offer
314-413-4334
314-413-4334
