SignUp Now!This is what we did on mine. No loop though
I used a Competitiond Engineering universal rear driveshaft loop and reinforcement plates for the lower control arm mounts from H&R Parts. Frame rails are notched , no additional reinforcements in the frame rails or between the rails. Full cage with the rear tubes going to the frame above the springs and another tube coming off the rear bars to the rear of the frame. The loop is welded between the lower control arm mounts and also have a diagnal tube going from the loop up to the upper control arm box. Many , many lo to mid nine second passes with 60' times from 1.27 to 1.33. No cracks in the b pillars or wavy quarters. Others have done it differently. I took the simple approach and it works. You will have to fab it. No bolt in deals.
