Well I was going to take the down pipe off of my car and have a Wide Band bung drilled and welded up. Well all the bolts in the DP seem to loosen just fine except one. I mean this bolt shouldnt be so hard to remove. I think its a grade 8 bolt but not sure so i dont want to snap the head off or strip it causing more problems, any suggestions on loosening this stuborn bolt? Im not sure i used anti sieze on this or not? I mean this bolt actually springs the other way when trying to loosen it if that makes sense
