I wanted to know if anyone knows the specs on these bolts?  I had to pull my engine and didn't pay too much attention and some of the bolts are shorter than the others.  Some are 3/8" x 1" and the other measure 3/8" x ~1-3/8.  Again I didn't pay attention to which came from bolt hole and also a couple of the bolts had washers on them, which again I didn't pay attention to which bolt hole they came from.
If anyone knows the exact spec or if there is a range(bolt length) that will work please let me know, also let me know if the washers are necessary and if possible at which mount points. The same with the shorter bolts, if anyone knows which mount points they go to. I know this is a lot to ask.
Thanks,
Charles
Thanks,
Charles
