turbov6joe
Signal 1 J-12
- May 22, 2002
Boost dropping from 25 psi to 12 psi on the 2-3 shift... need some help!
I'm still loosing boost on the 2-3 shift and can't seem to figure it out??? Basically it drops from 25 psi to around 12 psi then slowly climbs back up to 25 psi the rest of the pass. Someone suggested it might be the HD WG actuator, another thought it might be an overly rich condition due to my LOW EGT's (1350º's), and another thought it had something to due with the tranny taking SO long to make the 2-3 shift (stock/sloppy tranny), but why not on the 1-2? I'm using a new TE44 with a mildly hogged out 90º elbow and a 2.5" ATR DP. Do you think that it has something to do with the boost backing up in the elbow/DP at this high of a boost level? If I lower the boost to say 23 psi, the problem is much less pronounced if not at all. It only seems to act up at the 24 + psi level and higher??? Although not a huge problem, I am loosing a bit of ET and MPH while the boost is taking it's ever loving time to build back up to my set level... As a side note, I'm seeing just a small amount of KR (low single digits)on the 2-3 shift, but surely this is not enough for the ECM to pull out that much timing an thus cause the boost to drop off as it is??? Any other ideas at all?
TIA
TIA
