meanchicken
gallo vicioso
- Oct 6, 2007
tried coil pak, module and wires and it doesnt stall but it still sputters under hard quick wot runs. i guess it is either cam or valve springs. i still think i hurt the springs from over reving by not knowing it was in second and ran it to 7,000 rpm. because after that it started to run like ****
I don't think one over rev would kill your springs, but....Possibly you floated and slightly tweaked a couple valves....?
Have you checked the rocker shafts and rockers for any cracks or tweakage?
I used RJC shaft strpas on my rcker shafts as a safe guarde against these shafts known occasional breakage under heavy loads.
