- Feb 18, 2006
Brian, do you have the alky on? What happens if you turn it up?
try to rev it in neutral(wot), im thinking its still gonna nose over at around 4800, without boost. youre problem is starting to sound more and more like mine!! my car surged and noses over at 5800rpm(no limiter since its an alky chip) i was gonna shift at 6k and thats how i found the limiter that high up. it acts the exact same way your car does, just completely cuts out and wont catch itself until you let off the pedal. i even emailed eric at TT and had him double check to make sure there isnt a limiter on my chip. i think its ignition, its obviously not cam, maf, boost, fuel, or voltage related. hopefuly its the module and you figure it out for both of us :biggrin:
i can rev it to 5000 in park and it doesnt do it. it is starting to cut out at 3000 now
Did you try the module yet? If not don't report back until then...![]()
K.
put a brand new gm coil pack and module on and !!!!!!! you ready guys!!!!!!!! didnt do $hit!!!!. going to put the old fuel pump in and see if it helps. just put in a reds xp pump a month or so ago. just bought it because i put in a new tank so i figured might as well do it all. it is whining louder than normal like it is straining
fuel pressure is fine and yes under 15 psi its fine. even with the wastgate disconnected it just dies at wot at 4800
If your previous statement is true, that would rule out the fuel pump... you DID verify fp is rising exactly 1:1 with boost, rite??? (of course you did, otherwise you would never make such a statement..... :tongue: )
yes it is rising but my 02's are low 700's with alky and 17psi of boost with the timing down low a 20 and 18 for testing reasons. maybe i am losing volume not pressure
I tested a BRAND new coil/ign module for GNAT87 that he sent me with my Caspers tool. It had a bad tower on it...but it ohmed okay. The ohm test didnt show the issue. Send me your old one and I will tell you for sure if its working or not. PM me Brian.
hey thanks for the offer but i had it tested today and it is fine.I tested a BRAND new coil/ign module for GNAT87 that he sent me with my Caspers tool. It had a bad tower on it...but it ohmed okay. The ohm test didnt show the issue. Send me your old one and I will tell you for sure if its working or not. PM me Brian.
How are you recognizing O2 values, scanmaster or? Anyone near you that can hook a Powerlogger up to the car to make a couple files to share with us? Verify wot fuel pressure? i did verify with the scanmaster and the fuel pressure is 1 to 1
Pull the drivers valve cover and verify the camshaft lobes are still there...
K.
ran good for a month then this started all of a sudden. but wo knows about the rockers. just tired of spending moneyMan i hate to say we're all over the place on this, coils, fuel pump, etc. atleast you've done your spring cleaning. lol.
anyway Quip If you look back at my post about the spitting out the exhaust (which i dont understand since you dont have adjustable rockers) My rocker arms were being changed after 1 broke so i had to go back put one 1 in and decided to change them all out on one side when i put them back on it wouldnt crank, it turned over but wouldnt crank, so i had something out of adjustment. kept tinkerin with the valves adjusting maybe the middle one (keep in mind i havent done it before) i got it close and then my car crunk but it had at idling sound like a fast spit / spuddering coming out the exhaust.
spit spit spit sound , you get the idea, went to the comp site took my time and adj. all ea. rockers per instruction and the car sound and idled beautifully and QUIET for roller rockers so that was my problem out of adjusted rockers, even though i havent done it before im now a pro. (scorpion) rocker adjuster on my roller rockersNow this was mine but like i say since you dont have adjustable i still wonder if they are related problems.
new hoses with tbar clamps. now this is just a thought. my chip that i have is set up for a stock motor and a ta-49. now my new setup is te6031 and fully ported heads and intake. could not getting it reprogrammed be the problem. i didnt have an issue a month ago because i was running 15 psi and had my wot fuel at 10%. JUST A THOUGHT!!!!Since we're still shot gunning.
How about loose or leaky intercooler hoses?
