When you press your brake pedal, fluid under pressure moves your wheel cylinder piston out to press the shoe against the drum. Since pressure is measured in psi (per square inch) the larger cylinder has more surface area for the fluid to act against so it presses the shoe against the drum with more force. The heavier load on the engine allows the turbo to build more boost before it overpowers the brakes.
