Any suggestions??? 85 gn with front mounted intercooler.. repositioned the throttle body from the turbo and tapped it into the intercooler pipe next to the intake.. This improved the lag and the drivablity of the car.. However, at WOT and 18 lbs of boost it's flattening out and fluttering. I'm told it's from the vacuum lines not being hooked up properly.. Any suggestions out there?
Rod
Rod
