Car will not hold any kind of boost when pressurized from the inlet of the turbo....air coming from where the cover meets the the turbo right by where the drain is...feels like air is coming from between the oil return gasket as well....only time it smokes is when idling for a good while and revving or driving after....my question is how does this affect everything....is the area behind the compressor wheel in vacuum when the turbo is compressing? Would this be drawing un-metered air in under boost or blowing out? What about not in boost?
Looking for nice technical answer...maybe Patrick can chime in on this or someone with some real solid info....all my boost leak experience on my ricecar would lead me to believe this is causing me to run way off the compressor map even at stock boost and this should be throwing my part throttle fueling waaayyy off but it doesnt seem to be....
No shaftplay whatsoever and never blows anything under boost....
