boost level's at idle?
tsaltario
Still learning!!!!!
Is there a normal negative boost level you would expect with our cars while at idle? Mine sits around -12#'s when at idle.
TJ
Vacuum
It's called vacuum. :smile: It varies from car to car, many things can affect it like camshaft duration and vacuum leaks. Anywhere from -10 to -28 psi. Obviously more is better for vacuum brake setups.
TJ
Are you sure you're not seeing 12" (InHg) of vacuum? I doubt you're seeing -12# since that would equate to about 24" (InHg) of vacuum.
Most cars will idle between 12-16" (InHg) of vacuum.
So I believe you're reading the vacuum side of the gauge and misinterpreting it as - boost.
Oh yeah, It probably does read as vacuum. Never noticed the diff. Will check again tonight when I'm driving home.
TJ
