EyeTalk2Trees
 - May 29, 2001
ON my 84 GN (purchased a while ago, just started working on it) I rechecked my vaccum lines and everything was hood up no leaks but some where not in the correct position(not going to the wastegate.  THere where other probelms with the car that was causeing problems, ecm going out, burnt injector harness, things of that nature, now its all sorted out i can't get over 8psi.  I try adjusting to no avail.  It builds boost quickly then slams into a wall, could this be a bad wastegate, or a faulty boost silinoid(spelling, and if thats what its really called)  I do have a slight exhust leak but that shouldn't stop the boost like at does (hits a wall).  And its not giving any codes
thanks
JoshZ
			thanks
JoshZ
