Boost Maxing Out at 20PSI
recently installed a TT chip, new injectors and meth kit, the chip was made for 25 PSI but I cant get more than 20. Waste gate rod is shortened all the way, 60MM older but good Turbonetics Turbo. I have ordered a new Magnaflow and will get rid if the Flowmaster this weekend, is there anything else that could be holding me back?
A couple quick things.
Non HD WG actuator.
WG puck not sealing on the flange.
intercooler hose clamps not holding pressure?
leak somewhere? Did you install a BOV perhaps?
You sure you are ready for 25psi ??!!??
Its only so much you can get out of the rod , Mine was set at 18lbs and I got a Hallman Boost controller that I have mounted under the hood and can turn it wherever I want , Up or down . Make DANG sure that Akly kit is installed and spraying correct before you take it to 25lbs
Stock motor?or does it have heads and cam?
I checked all clamps, all good
no BOV
I am definitely ready for 25PSI!!
I installed the Magnaflow tonight, I will test tomorrow when it dries up outside...
I am not sure on the heads and cam, made 370 to the wheels at 20 PSI which seems a bit high, could be some mild work done
