boost on 110
All of it.....until it detonates or timing begins to hurt your ET.
There is no SET # of pounds for a given octane, you can run as much as your car will allow, turn it up slowly till you see a lil bit of knock and turn it back down when you do.
110
went out in my gn turned boost up to about 21lbs of boost no knock but pulling like a son of a biscuit.
110
22 psi no knock but running low on gas headed to the store for more 110 but if i do see knock after next turn or when ever can i just add c-16 instead of turning it back down im only putting 4gallons of 110 in at a time so i wont have to mix it with the higher octane stuff.
Ive run 27-28psi many times on 110 without any alky. Thee is no set number. CR, timing, cam profile and other things will effect the detonation threshold. Dont wait for a little detonaiton as suggested. If your in doubt go with more octane.
