you would see a difference weather there is restriction or not. Typically, this is why the actuator is plumbed off the foot, because the pressure immediatly out of the compressor is going to be higher then once it enters the intake. You want the actuator to see the compressor pressure.... as the "Hit" it sees in the signal is what helps the diaphram over come the spring pressure.
This is why I suggest that the boost take off, is always from the manifold. it gives you the most realistic image of the amount of boost the engine is actually seeing.
Now, if you want to measure some type of inlet restriction, simply add a vaccum gauge to the port right before the turbo on the plenum. if you see more than 2"hg of vaccum at WOT then your carb is too small.
