Boost problems after 20lbs
I'm sure he had it rebuilt 12 years ago so it has to be good still
When you reach the 20psi, and the car falls flat, does the boost drop off simultaneously? May be the actuator or a vac hose collapsing possibly?
It will drop off a little..but then if I just back off the gas pedal a little boost drop off to 17 18lbs and pulls again..everthing fine..alky working fine..no detonantion
If you only had the turbo off then got this problem, I would check waste gate puck alignment to make sure it is sealing properly. What O2 milivolt reading do you get on scan master when this happens?
I would also double check hoses post turbo for boost leaks.
A misaligned wastegate will not make the car nose over.
Again look at fuel or air starvation.
Check your muffler . I had a clogged muffler that it did the same thing . I'm sure you have checked it though .
I have a turbosmart boost controller (Eboost street)that will do that if you over boost.Do you have a electronic boost controller?
